replay-protect
Configure a replay protect window that accepts out of sequence frames.
Syntax
Command Parameters
enable
Enables replay protect for the specified MKA profile.
window-size
Specifies the maximum acceptable difference in packet numbers between out of order packets. If a packet number differs from the number of the previously received packet by more than the specified window size, the packet is dropped.
Default
The default is disabled.
Command Mode
mka profile
Usage Guidelines
This command does not apply to all hardware platforms. For more information about feature support, see Fabric Engine and VOSS Feature Matrix.
